45Ricochet wrote:
I was a bit confused also Jim with the weights and ratings :H
That rear axle rating should be more like 9000 lbs I would think. The only limiting factor is the tires. I agree even the guys that use axle rating instead of GVWR usually don't go over their RAWR. In general a newer Ford F350 should be maxed out at about 3k lbs of pin weight.
This is the result of the GVWR being tighter to the total GAWR of the truck. Now days that is running between 90% to 95% of the total GAWR, so it is possible to exceed the GRAWR without exceeding the GVWR.
Keep in mind the F350 is SRW, not going to have a 9,000# axle rating, more like 6,100 to at most 7,000#.
