I was 30% over the GVWR for my first rig. I used it full time for a couple of years and several months a year for 5 more years. I had a Ram 2500 with a rating just under 10K pounds. The equivalent 3500 differed by wheel size and had one more spring in the rear. I improved the handling and capability of my truck with airbags and Supersprings. Eventually I also upgraded wheels and tires to 19.5s.
I really had no concern about the weight for the axles and truck in general. Tires were a different situation. In hindsight I should have upgraded tires immediately. Instead I ran through a couple of sets of tires and went 60K miles in the range of 5-10% over the tire ratings.
Just a couple more comments when it comes to tires. LT tires are rated differently than passenger tires. An LT tire is rated to carry the maximum load for the life of the tire. There is a considerable margin built in to the rating. The rating does include a safety margin BUT...... Tire performance is highly dependent on maintaining proper pressure. I always checked my TPMS to be sure the tires were properly inflated. Low pressure will cause a rapid build up of heat and quickly damages a tire. Secondly, tire performance is highly dependent on how the tires are used. Many RVs sit for long periods of time with little or no use. That is extremely hard on the tires. Dry rot occurs rapidly when a tire is NOT being used. I almost learned this the hard way. After 4 years under the bed of the truck, I put my spare into rotation. It looked fine when I put it on the truck. It sat in the driveway for a few weeks while I was preparing for a trip. In that time the dry rot became evident and the whole tire was covered with deep cracks.
Again, I no longer push the load rating for tires. In addition I am fanatic about tire pressure and I will not use a tire that might have dry rot due to age or lack of use.
