spitts55's avatar
spitts55
OVERDRIVE OR NOT
I have a 2011 travel trailer 22ft and a 2003 expler 4.6 class three hitch with trailer tow do i use overdrive all the way to my destination or not .thanks
  • peirek wrote:
    path1 wrote:
    I want the fluids (transmission and coolant) to circulate faster than in overdrive mode.
    This! It will make a difference in your Tranny fluid temps.
    :R
    Total B. S.tuff.
    The fluids pumped around via transmission are NOT going to "circulate faster" whether in OD or not in OD.
    What you MIGHT see though since the engine will be TURNING HIGHER RPMs is the engine COOLANT will get circulated faster to a certain extent.
    The engine fan will also be running faster but at speed will not have much over all effect.
    Folks tend to put WAY TO MUCH time and energy in worrying about engine coolant and transmission oil temps.
    Folks, please understand the STANDARD configuration of modern day vehicles from the time automatic transmissions were invented the transmission fluid is plumbed into the radiator via a short loop internally in the radiator.
    This loop is placed at the BOTTOM of the radiator tank where the engine coolant is the LOWEST temperature possible. This loop will keep the transmission fluid near engine coolant temps (that IS the way it is designed).
    Additionally with vehicles which are factory setup for towing they will have a SECONDARY transmission cooler plumbed in AFTER the radiator loop.
    99.9999% of the time this is plenty sufficient to keep the transmission temps well within the factory specs.
    With that said, the OP should FOLLOW the FACTORY RECOMMENDATIONS OUTLINED IN THE MANUAL as to whether or not to lock out overdrive.
    I myself HAVE NEVER locked out overdrive UNLESS the transmission continually "HUNTS" gears (down shift then up shift in a quick repeating pattern).
    I towed with a 97 and 2003 truck with 4 speed automatic overdrives and I can only think of once or twice I locked out over drive and that was only for that particular grade.
    Newer vehicles with Tow/haul mode is completely different, the T/H mode DOES NOT LOCK OUT OD.
    I would say if the manual does not tell you to lockout OD while towing then try driving with OD and if transmission downshifts and upshifts too much (up/down quick pattern) then lock it out. The continual shifting is actually where damage can come from, not the fluid temps.
  • Haven’t used OD for towing in almost 200,000 miles and never a tranny or mechanical problem or breakdown…
    Not to mention I get better performance and fuel mileage not using it while towing …
    I don’t know about newer trucks with the tow haul mode…
  • I don't know Chevies, but isn't the switch on 2010 and newer Chevies a tow/haul mode, as opposed to an overdrive lockout.
    The difference is that it provides engine braking and changes the shift points, rather than just preventing the vehicle from hitting the upper gears.
    I use it all the time in heavy traffic even when not towing so I don't have to slam on the brakes, but decelerate while on the highway.
  • FWIW, my long term mechanic told me to never tow my trailer without first locking out OD with the trailer mode switch. I have followed his advice, even with my new Silverado. I agree, check the manual.
  • Type of tow hitch has nothing to do with overdrive IMO
    If your asking...should I use overdrive or not when towing, I would read your owners manual for your vehicle specifics. Some people use overdrive when towing to get a little bit better gas mileage. I don't because I want the fluids (transmission and coolant) to circulate faster than in overdrive mode. And use vehicle as designed by the manufacture.
  • The vehicle owners manual should tell you, However most will say do not use the OD while towing. Your trailer may be pushing 4K pounds? your 4K might be to much weight I would not use OD when towing over 2,500 pounds, but still I'd check the owners manual for the vehicle, glad you have the class 3 hitch....have you practiced your maneuvering with the trailer attached? If not find a big empty parking lot and practice, practice and practice some more. Happy Camping!
    2014 Puma 30RKSS
    18 Days Camping since delivery June 4th!
