- Cummins12V98Explorer III
RCMAN46 wrote:
Cummins12V98 wrote:
Me Again wrote:
However in towhaul it will not shift to 6th until 65 MPH. 3:42's and Austin. Chris
RCMAN46, I hope this clears this up for YOU.
He is the "from what I have been told" person. As HE has EVERYTHING to do with my comment.
Thanks Chris!
Posted: 06/20/17 09:56pm Link | Quote | Print | Notify Moderator
From what I have been told tow haul will not allow use of 6th with the AISIN trans.
MeAgain what say you??? "
Not sure how anyone would know that from your above quote. Plus your statement is totally incorrect. Also as an owner of an Aisin why would you make such an incorrect statement.
I guess you would not like to post my CLARIFICATION!!!
"MeAgain has the 3.42 gears, I have 4.10's. In 6th I am 1,750 rpm's and he is the same in 5th. I am wanting a confirmation from what I "remember" he said about his staying in 5th towing at the upper limits of his trucks ratings while in TH."
Are YOU happy now?????????????/ - BedlamModeratorMine acts quite differently with 4.30 gearing. Most of the time I stay in 6th. A 3000' climb is usually in 5th and a 4000' climb in 4th.
- transamz9Explorer
Yes, I believe I already said that. It also won't shift into 5th until 55. - RCMAN46Explorer
Thanks Chris!
Not sure how anyone would know that from your above quote. Plus your statement is totally incorrect. Also as an owner of an Aisin why would you make such an incorrect statement. - Cummins12V98Explorer III
Thanks Chris! - Me_AgainExplorer IIIHowever in towhaul it will not shift to 6th until 65 MPH. 3:42's and Austin. Chris
- transamz9Explorer
RCMAN46 wrote:
Cummins12V98 wrote:
Your signature shows you have a Ram with the Aisin transmission.
You also have stated several times in other posts how much better the Aisin is than the Allison.
Confused that you do not know how your transmission works.
Not sure what I have said about the Allison has to do with this???
What did you mean by this statement? "From what I have been told tow haul will not allow use of 6th with the AISIN trans." I do not see where what MeAgain has has anything to do with the question submitted.
As for the Allison has nothing to do with this but you have often indicated you are the expert on the automatics used in the Ram and GM trucks.
I would think you could have answered the question I put in quotes. I am curious what is the correct answer?
Can tow Haul be used with the Aisin in 6th gear?
Simple answer is yes. - dapperdanExplorerI have the Aisin with 3:73's, I use 6th gear all the time in tow/haul pulling our Suites. Depending on the grade I will lock out 6th to prevent up and downshifting frequency going up. Going down usually lock it into 4th, not higher than 5th, EB ON. :B
Dan - RCMAN46Explorer
Can tow Haul be used with the Aisin in 6th gear? - Grit_dogTrailblazer2016 Silverado 1500 does not lock out any gears in tow haul.
