Freep
Jun 09, 2020Explorer
Boondocking2019 wrote:
On my 2012 Ford F350 I installed a RoadMaster Sway Bar which help reduce the Sway but Im looking into shopping / research to adding larger spacers to engage the Overload Springs earlier. I have the 500# Airbags which I usually air to 20lbs and the Overloads are just slightly engaged. I know about the TorkLift Spacers but my questions is has anyone installed the Super Sway Stops? I like the option of the Spacer that can be removed for adjustment if needed. Thanks in advance for input.
https://www.supersprings.com/shop/sss-3/
I bought my truck with the torklift upper stableloads(which are pretty much the same thing) already installed and a few months ago installed the lower stableloads and my porpoising is completely gone, sway is pretty much non existent too. washboard roads aren't a big deal anymore either.
I was very surprised how well such a simple solution worked. I wish I hadn't waited so long to get them.
44,071 PostsLatest Activity: Aug 30, 2026
