Golden_HVAC
Jun 15, 2014Explorer
Why no overload springs? If they do not come from the factory, then you do not need them. Some owners have removed the overload springs to make the ride smoother, but hopefully that did not happen to your truck.
As long as you have 2-3" clearance between the top of the tire and bottom of the wheelwell, you are fine. The truck is designed to sag a little bit while loaded. If the springs did not settle about 1" per 750 pounds added to the truck, then you would ride like a lumber wagon.
Fred.
Fred.
44,027 PostsLatest Activity: Mar 05, 2025
