- More2ExploreExplorerNice find and fix!!!
- joeshmoeExplorer III
kohldad wrote:
And now the kids can crawl through and use the restroom.
I sure hope you mean when you are stopped. Can't believe you are in such a hurry and so pressed for time that you would put your kids life in danger just to save 5 minutes.
Lots of dangers in life. Nolan is a grown man with plenty of experience. We thank you for your Safety Sally concern though.
Now, about these anchors, which is truly a safety concern..... - BurbManExplorer III
Not any different than using the lav in an A or C while it's underway. Kids probably think it's fun crawling thru the hatch!
How do you keep the rain out with the window removed? - JaxomExplorerConsidering all the things we did as kids, this is small potatoes.
Living is a risk. Keep the kids safest, never let them out of their rooms.
OP, I'm glad you got the problem taken care of to your satisfaction. Does the innertube rub the paint off the truck or camper? - kohldadExplorer III
I sure hope you mean when you are stopped. Can't believe you are in such a hurry and so pressed for time that you would put your kids life in danger just to save 5 minutes. - anutamiExplorer III
grizzly8 wrote:
i hope mellow mike see,s this 2012 wolf creek camper tie downs tearing out!!!!! CANT GET NORTHWOOD TO EVEN RESPOND LET ALONE FIX THEM AND MY DEALER IS WORTHLESS!!!CAN ANY 1 HELP PLEASE.HE FIXED 1 WHEN CAMPER WAS 2MOS OLD OH SORRY I SAID FIXED NOT THEY BANDADED IT!!!!!AND BY THE WAY I HAVE TORQ LIFT FRAME MNTS PUT ON WHEN I GOT CAMPER
Are you having issues with your anchor bolts or pass thru window? More info is needed and pictures are even better. - grizzly8Exploreri hope mellow mike see,s this 2012 wolf creek camper tie downs tearing out!!!!! CANT GET NORTHWOOD TO EVEN RESPOND LET ALONE FIX THEM AND MY DEALER IS WORTHLESS!!!CAN ANY 1 HELP PLEASE.HE FIXED 1 WHEN CAMPER WAS 2MOS OLD OH SORRY I SAID FIXED NOT THEY BANDADED IT!!!!!AND BY THE WAY I HAVE TORQ LIFT FRAME MNTS PUT ON WHEN I GOT CAMPER
- anutamiExplorer IIIThank You Northstar!!!!!
Finally found the correct pass through window Northwood should be using is actually the one Northstar uses. Called them up and ordered me one.
Swapped out the pass thru window...no more leaking through the weep holes :)
- joeshmoeExplorer IIIThat sucks. Yeah, there's gotta be something better. Good luck
joeshmoe wrote:
Whacha up to? Why the change?
I have resorted to removing the entire window in order to gain access, and have to re-install the window when I take it off the truck.
There has to be a better way
