desertfoxjr's avatar
desertfoxjr
Payload Advice
I own a 2014 GMC Duramax 3/4 ton 4x4 Crew Cab truck with a 6'6" bed. I have talked to a number of people who have given me a range of advice about the size (weight) TC I can safely carry, along with mods that will offset weight discrepancies. i have narrowed my search to TCs with wet weights the in the range of 2600 - 3,300 lbs. I believe my payload is 2440 lbs. As experienced TC owners, I am interested in any advice or suggestions you can provide me.
Many Thanks,
Harold
  • wnjj's avatar
    wnjj
    Explorer II
    I didn't realize "wet" and "dry" are punctuation. :p
  • It nice to have fellow member on forum, who will follow you and check every punctuation.
    Only bad part is that he plays stupid between.
  • Kayteg1 wrote:
    Quick calculation >>> 33000 lb dry camper will put about 4500 lb wet on your rear axle.
    Add truck own weight and tell us your tire ratings?
    But the OP said 3300lbs wet, which typically includes bare camper+all options+ full tanks, in camper speak.
    It would be hard to get another 1200lbs of personal gear and food in the camper (unless you're living in it and have every nook and cranny packed full). Not everyone has a 7000 or 8000lb camper, whichever your recent weight claim was in a different thread.
  • Do you plan on also towing something. Trailer tongue weight can add significant weight to the rear axle/tires.
  • Quick calculation >>> 33000 lb dry camper will put about 4500 lb wet on your rear axle.
  • Keep tires and axle weights under what you are allowed you will be ok I weigh in at about 500 lbs over GVWR but under axle and tire capacities truck works just fine
    Dave
  • Being a short bed truck, size is already limited to short bed campers, which automatically keeps them in the range you can carry on that truck. You should be able to carry whatever camper fits on it.
    If it needs a bit of help, airbags or overload spring spacers (Timbrens or similar), a sway bar and some good shocks should have you set to cruise.
