ruthiebaby88 wrote:
Ok - saw a 1 ton dually -
Should be able to carry just about anything right? Sticker in glove box says 'This information is furnished to indicate the manufacturer's recommendation regarding the use of a slide in camper with this truck as manufactured.'
cargo weight rating: 2482#. Would this be x2 since it's a dually? Seems very low?
It did have a crew cab. 2482 would not get you much with a weighted camper and 4 passengers.
You would look at the rear tire rating - the lower of the two ratings printed on the tire is the one you would use when looking at a dually. Then X2 that rating to find your allowable "payload".
Very simple.
The glove box statement probably concerns horizontal center of gravity and or braking ability or bed deformation or a combination of things.
