mkirsch
Dec 28, 2016Nomad II
That's the "by the book" way to calculate payload: GVWR - actual empty weight
The reality is that if you want one of those jahunga behemoth campers, 4300lbs is not going to cut it. You're going to have to fudge the numbers by working off the axle weights.
towpro pretty well describes how to do it. You need actual weights for each individual axle. The reality is you probably have between 5000 and 6000lbs of payload capacity over the rear axle, which is where the weight of the truck camper ends up anyway.
44,068 PostsLatest Activity: Jun 09, 2026
