fla-gypsy wrote:
45Ricochet wrote:
Three type of people out there OP.
1. Folks who follow manufactures GVWR. Manufactures are pretty dumb folks though as they know nothing about the truck they engineered :B
2. Folks who run by the GAWR or axle rating. Heck a 9350 rated axle can always hold that much weight with 6k rated tires :E
3. Then there are those who just hitch up and go. I'm sure the Yugo will be just fine honey.
Life is choices.
Let me add 1A; Those of us who think the manufacturer actually did the engineering and therefore NONE of the many "maximum ratings" should ever be exceeded!
This type never has to rationalize away anything in their mind or to anyone else concerning whether a maximum allowable rating was established for safety reasons, or warranty reasons, or performance reasons, or liability reasons, or if the tires or the axle is the limiting factor, no wait, maybe it's the mythical "missing" leaf spring? Is it possible that the manufacturer who established the "Not to exceed" rating really meant it, or is it just a recommendation? Apologies to the OP for the hijack rant but your question has already been answered many times very accurately by previous posters.
Welcome to the forum !
First, decide whether you believe in the ratings (specifications, limits, etc)
or not
If not, then do whatever you wish. It is a free country till you intrude into
others likewise freedoms. Then our society limits your freedoms in
many ways. Know that you have taken the OEM off the warranty hook
if still in warranty and off the liability hook. On that, note that
'recommended' is a defined legal term and if a driver should ignore
that 'recommendation', that too takes the OEM off the hook...
If yes, then read and ask question to learn how the system works. Yes, a system
and that all of the various components, sub assemblies, and systems work in
concert with *EACH OTHER*
There is fine print in all OEM ratings. The fine print establishes
and/or modifies the basis used to derive those ratings. This is VERY
important, as most folks take any single rating as an absolute, and
lost to them is that it is only a component in a ratings system
Or that there is fine print that modifies the conditions on which
that rating is based, or derived from
Then learn or already know what the definition of 'rating' is, then that
is part of your yes/no decision on ratings. Many seemly do NOT truly
understand the definition of rating.
Notice that the acronyms all have an 'R' in them. GVWR, GAWR, MTWR,
GCWR, etc.
Payload rating is what any vehicle is rated to carry (weight to pavement)
Tow rating is what any vehicle is rated to tow...reference that fine
print comment above
Like that Toyota commercial that has a pickup 'towing' the Space Shuttle
that weights hundreds of thousand of pounds. That is towing on a good
day and am sure that Tundra is NOT rated to tow that amount.
There will be tons of the 'sure you can', etc, but the only person
responsible for the setup is the driver. Like your spouse driving
while you rest. Many come here only looking for that 'sure you can'
and they will get many...
Here is a diagram made up from another members diagram showing how
the whole ratings system works in concert. Remember the old axiom
of a chain is only as strong as it's weakest link...in this case the
weakest or limiting 'rating'...
howmuchcanitow
