harmanrk wrote:
hmknightnc wrote:
The reason you see payload/GVWR/Axle ratings discussed so often is unexperienced people tend to look at only tow rating and believe that is what the truck should be able to pull. In reality tow rating is the maximum a truck can pull with a theorical trailer. TT and FW with thier associated on the heavy side tongue wieghts and large wind resistance aren't even close to that theorical trailer
So for theoritical tailer, that would max out the tow rating, you would something like a hay wagon, with wheels at the four corners, and basically zero tounge weight. Not that you would want to pull any hay wagon I have ever seen at any speed.
Well not quite that bad. Something like an equipment trailer carrying a relatively low hieght load with wieght adjusted such that there is just enough tongue wieght to prevent sway
Think about this way. You can tow a heavier flat bed trailer than a boat trailer and a heavier boat trailer than a TT/FW. All with the same truck.
