ShinerBock
Jul 04, 2019Explorer
eHoefler wrote:
Compression is only one part of the puzzle. The lower compression motor has a higher output turbo, which translate to higher compression when running hard. More air + more fuel = more power. As far as fuel economy, I am with in 1/2 mile per gallon of my old truck, pulling the same trailer and the same roads. With just over 2,000 miles on this beast. As miles get put on, I suspect the milage will only get better, like my 4 previous Rams.
The lower compression allows for more power while staying within NOx emissions. You could not have that same power output with the 19.0:1 compression ratio engine and still remain NOx legal. I have to check the specs on Cummins Quickserve when I get back to work, but I don't believe the turbos are different just the engine tuning. Both engines can easily and reliably make well over factory power levels, but they cannot do it and stay emissions legal.
44,068 PostsLatest Activity: Apr 17, 2021
