So we did have food,40 gals of water,BBQ, one 30lb propane tank full and does have a gen set, solar panel, Sat dish on it. I am 10,200 on the rear axle at the scale I stopped at. The tires are rated at 2910 each in the rear that should put me on the tires at 11,640.  The camper we found out has a propane leak some where in the tank area, i think it might be the switch valve/regulator, I am going to soap test as soon the rain stops,the bathroom vent doesn't close all the way and small little things. Yes it was the one in Evergreen
