packpe89's avatar
packpe89
Picking Up New (to me) Ram 2500 CTD, a few questions
After debating 1/2 ton or 3/4 ton, came across a good deal on a 2016 Ram 2500 Mega Cab 4x4 with the CTD and only 50K miles. Picking it up this afternoon. My previous diesel experience was an '05 F250 with the 6.0. With that, there were all kinds of additives folks recommended, such as seamfoam, cetane booster or adding oil to the fuel tank and frequent oil changes and fuel filters.
Looking online, I'm seeing oil changes every 6mo or 15K miles and fuel filter once a year. Is this good? Synthetic?
My F-250 did not have the exhaust brake and the Ram does. Should I always use the exhaust brake or only when towing or only when towing grades?
What else should I know or be ready for?
Thanks
  • The RAM is a whole different truck than a Ford 6.0. The RAM should just need basic fluids and maintenance (like a truck should). The 6.0 was a temperamental engine that required exacting care and maintenance to prevent disaster.
  • Make sure the recall work has been done, especially the water pump. The original pump in mine failed at 30k-ish miles and left us in a pretty good bind. Beyond that just fuel and do the recommended fluid changes. I've always run synthetic oil in mine mostly because of cold winters. If I didn't see below zero temps every winter I may just run the standard stuff.
    I throw my exhaust brake on for more than just towing but I don't use it all the time. When I'm towing I always have it on and set it to Auto mode, along with T/H.
    You won't regret stepping up to a diesel, and you got a pretty good one. I've really enjoyed my '15.
  • I have a 2014 since new . I never add anything except fuel . Synthetic oil always at 10k or so . Exhaust brake , most of time . My truck it is sometimes difficult to use tow/haul and exhaust brake at the same time when going down long mountain grades , I will turn off tow/haul on long decent.
