You do not lose payload with the diesel engine. 100% of the engine's weight is on the front wheels. More than 95% of the weight of a camper or other load in the bed is carried by the rear wheel. I have a diesel pickup and at the CAT scales my 3400 lb. camper shows as adding 100 lbs. to the front wheels and 3300 lbs. on the rear wheels.
People get confused by the GVWR which is a rating classification done for DOT and your state DMV. The manufacturer provides a payload rating that takes into account a passenger load and for every seat in the cab a 150 lb. deduction is made. That is why the regular cab trucks have the highest payload ratings.
My truck has a front suspension designed to handle the weigh of the diesel engine (and a snow plow). The rear axle and wheel bearings supports up to 10,900 lbs. so the weakest link is the tires and or the leaf springs. Both items are easily upgraded, unlike air bags and ABS braking.
Newer trucks are likely to have stronger and stiffer frames, better brakes, better engine cooling, and other engineering improvements. It is also much easier to find aftermarket equipment for newer trucks.
