- HuntindogExplorerAll this talk about super singles is like apples to oranges. There is no super single made that would be the equal of duals like there is for the big rigs.... I have seen a few that have spent a lot of $$$ and put those on a pickup... But it is not an equal as that tire is the equal of TWO big rig tires, not two pickup dually tires. So even though it is being done by some with a lot of money, it is a niche thing that only interests those that want to modify their truck to be "different" If it were effective in both cost and performance, it would become mainstream.
And as for comparing a dually with a SRW that is 5 years newer and stating that the newer SRW is better.... Well that depends on just what 5 year span one is talking about. From about 2000-2010, capabilities were pretty constant. The big three substantially redesigned and upped the capacities from 2011-2013.... But those capacities were raised for the duallys as well. So that argument falls flat.
And as for the OPs insistence on finding a test to prove or disprove the obvious.. Good luck. Most tests will be done amongst equals
duallys against duallys, or SRWs against SRWs, or diesels against diesels etc. Not sure any publication would seriously consider doing a test like the OP is wanting. Publications want to sell magazines. Doing a test that will have an obvious winner takes the suspense and interest out of such an article, and won't drive sales. - Cummins12V98Explorer IIIHigh profile trailers are where the Dually will shine.
- blt2skiModeratorI found no difference in handling a 12K equipment trailer tween my 05 dually with 8500 lbs of suspension, and my 96 K3500 that had singles, ONCE I changed out the SW setup with an 8500 lbs suspension.
I would also be willing to bet, generally speaking, that if you took a rig with singles, that are AS WIDE, same suspension tire capacity etc as the dually, BOTH would handle any given trailer the same. Most tests I have seen comparing semis with super singles and duals, the SS setup handles BETTER than the dual tired drive setups. Real issue is to a degree, the human factor.
This is not to say that some single tire tread designs may not be as good as some dual tread options.....Most SS tires I have seen advertised are more hwy oriented. If you drive in snow.....I would imagine a dual setup with traction tires would do better. With or with out chains.
But from a typical pickup standpoint. Duals will generally do better with larger loads than singles etc.
Marty - BenKExplorerRepeat...didn't say dually...it is the track...AKA width...
BenK wrote:
Common sense is very UN-common...
stand with both feet touching and have someone push you sideways
Again with feet wide apart
Which one will have that person pushing you sideways easier?
But...this is a common sense topic, so tough to get common sense into the
discussion... - RinconVTRExplorer
valhalla360 wrote:
RinconVTR wrote:
Take the stability of 2 rear tires and multiply by two...give or take.
OP, am we missing something? Is there a hidden question here?
Wow, not even close to reality. By this logic is we fit the entire length of the axle with tires (say 8 tires) it will be 8 times as stable (it's not).
The answer is yes, dually's are more stable but as long as you are within weight ratings, there is no safety issue. SRW trucks don't fall over because they are missing the training wheels. You would be very hard pressed to document a situation where a SRW would roll but a dually would stay upright while towing.
I suggest you start watching semi's. You will notice a great many are going singles (a little difference as the outside width is held steady). If they were falling over left and right, trucking companies wouldn't use them. That is about as objective as you can get on the subject.
The reason to get dually's is because you need the extra load capacity.
Question was about stability...not load...not safety...stay on topic. You answered the question yourself...but yet you go on.
If you look at the trucks converting from dual to single tires, they are not carrying the highest loads and the single tire is VERY wide. VERY WIDE! Now why would they do that? Hmmmm
Also stability while towing...IMO...does not mean resistance to tip over. Roller over "stability" I don't believe was the point of discussion here, but if it was, I'd simply take measure. The wider version likely wins. And is that not the dually? - rhagfoExplorer III
Bedlam wrote:
IMO: The extra weight of the DRW fighting the FW helped break the hitch sooner than the width keeping the truck upright. I also feel the kingpin was defective or worn for that separation to have happened.
So just how much extra does a DRW weigh than a SRW, 200# 250# maybe 500# spacers on the front, heaver wheels, unless Aluminum.
Is a DRW more stable that a SRW, it is basic physics! Wider stance, and far more tire capacity. :S - notevenExplorer III
BenK wrote:
Why my Suburban has -1.5" offset alloys....stock is +1.5", so the net for both
sides is an increase in track of 6"...plus that my rims are 10" with stock at 6.5"
Means another 3.5" wider track
Plus my tires are 10mm wider, so 10mm wider track
All adds up to about 10.5" wider than stock track, front and rear
A dually has an even wider track
It is not any one aspect, but all of them in concert that matters...AKA in context
If this guys car had a narrower track...think he could do this with the
exact same car?...or would he roll over?
This is part of what a dually does better than a single with a narrower
track...managing that 'push' and 'sway' from the trailer
leanbar sidewall aspectratio track
Would this car corner harder/be more stable with dual rear wheels? - larry_barnhartExplorerYou would have to have a serious thinking problem if thinking a SRW could be as stable and a DRW on a heavy fifth wheel.
chevman - BedlamModeratorIMO: The extra weight of the DRW fighting the FW helped break the hitch sooner than the width keeping the truck upright. I also feel the kingpin was defective or worn for that separation to have happened.
- The_Mad_NorskyExplorerThere is a forum member who uses the user name Veebyes.
Driving through Wyoming somewhere near Laramie on I-80 pulling their fifth wheel with dually truck, they got hit with a huge side burst of wind.
The kingpin of the fifth wheel was torn out of the hitch in the box and the fifth wheel ended up rolling down an embankment, destroying itself in the process.
The fifth wheel dragged the truck some over towards the shoulder of the road before the kingpin tore loose, but the truck stayed upright.
Veebyes has stated he believes the dual's prevented the truck from following the fifth wheel on down the embankment and rolling too.
Anecdotal, yes, but had this operator had a single rear wheel vehicle, would the results have been the same??????
44,056 PostsLatest Activity: May 04, 2014
