colliehauler wrote:
Cecilt wrote:
colliehauler wrote:
You can add additional braces for the floor for more support.
From top or bottom? If I open my access panel on my underbelly the floor is solid as a rock everywhere I can feel. This may not be the bottom layer of the luan but not sure how I would even access the luan/foam/luan if there is a layer of wood below this.
You have to go in from the bottom to add more floor joists. This would probably involve dropping the holding tanks to access. This is a major job and if your not sure it might be worth calling a RV Mobil tech.
Which is why I probably won't bother. Once I open up the slide for the fridge and stove I throw a 5' long throw rug on the linoleum which keeps us from feeling the softness in the floor.
