owenssailor wrote:
My Jayco also has a sot floor in the high traffic areas.
I am considering cutting out the affected area from the top. Then I will add supports to the aluminum cross beams at the right height to have 5/8 ply level with the remaining floor. I expect I would need stiffeners under the ply where beam spacing is very wide.
I'll put a but block along the longitudinal seams and then fill and level the seams with a thickened epoxy mix.
after that I will put in laminate click together flooring which I have since I put that in while touring this winter to try to reduce the flex feeling.
Does this sound feasible?
I am too old to be working underneath the trailer to try to fix the floor.
Thanks
On a previous camper, there was a very soft spot at the door. I cut the vinyl, top plywood and foam out leaving the bottom layer. I cut back to half over the aluminum supports. I used 2x8’s to fill in where the foam was and used plywood to bring back to finish floor. Painted plywood to match the vinyl, with aluminum trim to hold the vinyl down and cover the seams. With a throw rug, couldn’t see the repair.
