BigRick619's avatar
BigRick619
Please Help 03, Bigfoot 25B25RQ
Good morning guys and gals.
So to start off, I am sorry if this has been asked else where but I have spent 2 days reading and can not find the amswer. I also downloaded the owners manual and brouchere and nothing.
I am in the market for a 25B25RQ and I found one for 14kUSD (2003) . I will be viewing it soon. The seller has indicated that it does have a current leak that slightly stained the carpet in the rear. Leak is "coming" from a window seal not sealed properly.
He inherited the trailer and just wants to sell.
Here are my questions for you savy RV'ers.
1. Even if the trailer APPEARS to look good after i inspect it. Would you still stay away from it due to the known leak?
2. In 03 did bigfoot still use wood as the subfloor? A dealer i called claims they switch to aluminum but does not recall in what year.
3. I have heard that once water gets in these clam shell trailers, the water has no where to go and will just sit in the under belly and continue to rot the subfloor until it is softer then mash potatoes.
4. How can i get to that portion of the trailer to check for sitting water/rot?
Thank you in advance SO much!!
  • I've owned one of those, I'd bet that the water is condensation from the cheap window. ours did.
    the trailer is a thin glass shell with glued in stereo-foam sheets, colder than hell in the winter, furnace would never shut down. all windows condensed water and had streaks under them.
    the wood wasn't real wood, just chip board covered with wood colored sheet. which peeled when wet.
    worst trailer we have ever owned.
  • midnightsadie wrote:
    if your really in love with it? peel the wall back and have a eal look, then barter on the price. he has no money in it so a good deal can be made.
    To be honest, the 25b25rq is my dream rv, BUT i do not want emotions to steer me down the wrong path and right into a finacial and time heartache.
    If he will allow me to peel some back, i think that might be a good idea.. i mean the price already seems great, BUT a potential water damage repair can be SO costly. :(
    Just trying to make the right decision and i really appreciate any and all feedback from those willing to provide some..
    Ty for your input as well. :)
  • if your really in love with it? peel the wall back and have a eal look, then barter on the price. he has no money in it so a good deal can be made.
  • azdryheat wrote:
    Plenty of trailers without leaks. I'd keep looking. Keep in mind that where there's a water leak, mold isn't far behind. You can always peel up the carpet for a look see.
    You are so very correct.. the price just seems right, and happens to be in my area.. but you are speaking a lot of common senseical truth
  • Plenty of trailers without leaks. I'd keep looking. Keep in mind that where there's a water leak, mold isn't far behind. You can always peel up the carpet for a look see.
