ajriding
Jan 16, 2020Explorer II
mountainkowboy wrote:ajriding wrote:
Your only potential leaks are at the vents and windows really, and it is unlikely the water is able to run inside the fiberglass construction, it will have to leak into the camper which will be obvious.
and EVERY hole that's ever been put in it....lol. If you do proper maint, it isn't a problem, if you don't they will ALL leak and rot.
Having owned both stick and fiberglass I can attest to the high quality of a fiberglass shell. No leaks!
Wood: leaks. Maintenance will prevent a lot of leaks on a stick camper, but some you will find after it leaks. Fiberglass just will not leak, and if it does the fiberglass and foam are waterproof and the foam fills in all the voids so there is nowhere for water to go anyway other than the floor or back outside. To the floor and you know pretty quick you have a leak, no rotten wood years later to testify to a leak like a stick camper.
Side note: don't put any more holes than necessary. The factory who built my fiberglass camper used a screw for every screw hole on the roof vent. There must be 32 screw holes so they used 32 screws. Only 6 or 8 were necessary. The Lap sealant will do wonders to aid the screws and hold it in place. Lap sealant alone will hold it but the screws make the frame lay flat to the roof.
When I changed vents I filled in many holes and used just a few screws 2nd time around.
