jimh406
Jan 16, 2020Explorer III
ajriding wrote:
Fiberglass just will not leak, and if it does the fiberglass and foam are waterproof and the foam fills in all the voids so there is nowhere for water to go anyway other than the floor or back outside.
Of course, this is not true. It’s easy to find examples of significant damage in fiberglass shell campers as well. You just have to do a search.
Besides, many “stick” campers includiing my Host has aluminum studs with walls filled with foam. Yes, they have their own set of problems. It’s a double slide with tremendous amount of room compared to a “fiberglas” shell TC.
Bottom line is nobody has built a perfect TC. There’s always going to be a tradeoff. Pick the tradeoffs you want to make, but all TC designs can leak. Maintenance is important for all types because they all have holes cut in the front/sides/back/top.
