bobsbbqExplorerDec 08, 2013Plumbing connections for water.I have never had to do anything with the plumbing and I don't recognise these types of fittings and connections. I noticed a small leak at one of the 90 deg elbows. It looks like these clamps are a cr...Show More
K_CharlesExplorerDec 08, 2013Cut off the band and then try a hose clamp. If it stops the leak good, if it doesen't then you can replace the fitting.
Related ContentQuick connect exterior shower hose doesn't connect.Water pump?Nautilus P1 has leaking connectionsWhy no hot water?(Leak!) Toilet plumbing connection to Black Waste tank...
