schlep1967
Dec 09, 2013Nomad
Yes there are but you would be hard pressed to connect one to a fitting like the one at the top of the OP's picture. If the fitting is cracked and needs replaced a crimp tool and band is the way to go. I just replumbed my whole house from copper to Pex. Very easy to use. Took less than a day to replace everything from where it comes through the wall from the well to where it connects to the faucets. And I am not a plumber. The sharkbite fittings will work where you just have to replace a hose or piece of hose. But if a fiting is cracked they will not help you.
