Have a 2011 Rockwood TT model 8293RKSS. The roller bracket on one of doors has striipped threads and I need to replace it. Does anyone know if this would be a standard fitting or would I have to go t...
Found the problem. The plastic piece you screw into on the wheel truck fell out. There is a gap on the inner walls and I guess it dropped in there, never to be seen again. Found a small nut that would fit inside the truck and put it back together. Thanks for the info.
