mbloof
Jun 30, 2020Explorer
wnjj wrote:
For clarification, do you consider shocks to be a modification or not? They replace a stock part with an equivalent or better but since they are also a wear item you could consider them just replacements. The same question goes for the tires I suppose.
As I mentioned above, I did replace the shocks and eventually the tires but with no major notable difference with the shocks and the tires were the same size and load rating as the worn out OEM tires.
I'm of the thinking that 'wear items' are just that. If they wore out and you replaced them then you are not modifying your truck.
In my case the OEM tires were boarder line at best and underrated at worse. I upgraded them and count that as a modification.
- Mark0.
44,068 PostsLatest Activity: Jun 10, 2026
