westend
May 10, 2018Explorer
Talisman61 wrote:
Going IN lol should have clarified, I'll have a good 3 to 6" worth of downward angle prior to this.
Going this route since I dont think the slip fit fittings I got Slip fitting
Will work on the side. Pretty sure they are vertical only.
For the few times I've used them, the tank grommets work well. They never leaked. Your bulkhead fitting is OK but you'll need to make sure that you can tighten that gasket against the tank. I'd probably try to use some sealer if using that bulkhead fitting.
Good luck!
