burningman
Sep 30, 2018Explorer II
There’s no “dirty” 12V power, it’s DC. It’s not ideal for charging only because it isn’t regulated to lower its voltage when it senses less load, like a “smart” charger does.
This generator install definitely needs an exhaust system. Sure it’s a generator compartment but the sets its designed for aren’t portables. Even if fumes aren’t an issue, heat will be.
With a fan and an exhaust I think it could work out fine.
Exhaust is tricky if you have to be able to easily remove the set to fuel it though.
