jaycocreek
Oct 23, 2017Explorer II
No one answered my question about the Wave heater. Does it warm objects like most of that style heaters do, or warm the air like a furnace does.
I have used all three Wave heaters and both the Big Buddy and Little Buddy in different RV's..I currently have a Wave 8 and both of the buddy heaters..In answer to your question,they heat the air just like a furnace does..depending on which you have,you can feel the warm air the length of the kitchen/front room in a 30 ft trailer with a Wave 8.
I just used the little buddy in my 9.6 Lance with it sitting right below the step to the bunk and felt the radiant type heat at the door.I personally have never heard of anyone dying using a catalytic heater used correctly or incorrectly..They need a window cracked, which is never a problem because of the radiant heat..Thousands of RVer's use catalytic heaters in there RV because of not needing electricity and the constant output of radiant type heat.
