Just got my unit out of storage . When hooking up to the landline . The breaker pops . Also the generator won't start . Don't know if these two are Connected in some way . Need some help!
Gen probably won't start due to low battery........
AC breaker tripping is due to other issue. As suggested turn off ALL AC circuit breakers then plug in........close CBs one at a time until source breaker trips.
Location of transfer switch........?
You would need to trace where shore power line goes and where generator power line goes..........or trace back from main ac power panel. All three will end up at the transfer switch
