lostnconfused's avatar
Apr 16, 2015
Popping breaker
Ok I bought my first camper, and I know a little bit about electrical and mechanical. So when I bought the camper I went to plug it into my garage and noticed the plug was worn out. So I bought a new 30amp plug and wire it up. So after I got it all wired it worked good minus being shocked when I touched metal. So we went camping plugged it into the camp site and every thing worked great and we had a great weekend. Get home and I plug it back into my garage and get shocked, so naturally I assume it is the ground and I have it wired wrong. So I took the old plug and cut it open to realize I did have it wrong. I had the white wire running into the ground and the green into power. So I rewired it the correct way and that is when it went down hill. I popped a general breaker in the camper and smelt something like it got hot. Checked all my wiring and everything seemed to be correct. The breaker I am using is a two pole breaker with 30 on each breaker and a bridge to join them. I rewired it plugged it in and went back to the camper and sure enough it popped it again, as I was getting ready to go unplug it my microwave through a spark and I am sure it is fried. I need some good advice on why it is doing this and what I need to do to fix my problem. Please help
