bigtime_077 wrote:
I already checked and none of my 120 volt outlets in the camper run through the invertor only the shore power hook up. I am at a loss here and I am looking for a little guidance.
Thanks in advance, Jason
first, i think you mean CONVERTER, not inverter. unless you installed one. but i seriously doubt an inverter could run a heater unless you had a minimum of 4 batteries.
not sure if you know but your 120v outlets ONLY work on shore power or hooked up to a generator.
your trailer's CONVERTER only converts 120vAC power to 12vDC power and also recharges the battery. all RV's have converters but most don't have an inverter, which inverts 12vDC power to 120vAC power.
but this takes a lot of battery power for what you want to use one for.
when we have electric hookups, we use a simple ceramic heater.
