RoyB wrote:
We don't have any luck at all using our 2KW Honda EU2000i unit to operate our 13,500 BTU Air Conditioner. I can turn off everything in the tailer and maybe get it to startup but as soon as it cycles it trips the breaker...
SO if you are planning on running the air conditioner then you will need something bigger than the 2000Watt generator...
I purchased my Honda EU2000i back in early 2008 and it has run flawlessly since then. I have mine secured to the tailgate corner of my covered truck bed and pull it out into the tail gate when I need to charge batteries on the traiter each morning. I can plug in my trailer using the RV30A-15 long dogbone adapter cable from WALMART for the required three hour generator run time...
Always starts right up on the first or second puyll of the rope...
Runs everything in my trailer except the Air Conditioner or high wattage Microwave unit...
Roy Ken
Did you install a "Soft Start kit" in your air conditioner? What wattage is your microwave? My 2000 runs our 1500W microwave oven.
