RoyB
May 17, 2013Explorer III
I almost think you are not doing the OTA HDTV scan right.
Turn on your antenna panel push button which applies 12VDC power to the BATWING antenna pre-amp. Then point the antenna to a known town that is broadcasting high def TV signals.
Then go to the HDTV menu and select ANTENNA from the menu on your HDTV. Then you have to scan in the digital TV station before you can see them.
What I do is start scanning for digital TV signals and if I dont see any digital TV signals start be counted on the menu screen in the first 15% of the scan I will stop the scan and move the antenna slightly one direction or the other and re-start then scan.
The DIGITAL TV SIGNALs has to be logged-in these to the HDTV before you can view them. Not like the old days where just moved the antenna to get a snowy signal and then move around to get it better.
In the digital TV world you either get a perfect full screen high def signal or nothing at all...
Try this at home and experiment on how to tune them in. You will be amazed what kind of high def picture you will get from the Natl Broadcast Network (CBS-NBC-FOX-ABC-PBS)...
There is a HDTV signal finder you can have inline with the RG cable that will MAX UP on the digital TV signals. This is the SURELOCK Digital TV SIGNAL FINDER... The new HDTV signal all operate on UHF frequencies and you have to be pretty zero'ed in on them before picking them up in your TV digital scan. Using the SURELOCK finder you just move the antenna back and forth until you find the signal - keep reducing the gain until you MAX the idiots lights and that will be the direction of the HDTV transmitter. Then you can ru the DIGITAL SCAN from your HDTV scan menu.
NOTE: I forgot to add you have to have a digital ready HDTV to pick up the digita TV signals... We use the 22-inch VIZIO HDTV's in our campers.
Roy Ken
Roy Ken
44,066 PostsLatest Activity: Jul 25, 2018
