wmoses
May 17, 2013Explorer
kjoh75 wrote:
Just checking back in again. Thanks for your comments. The reason I had made this inquiry is because there are times when you do not have access to cell coverage. No WiFi, No Net flix, no cable hook ups. .... Correct me if I am wrong but shouldn't my DirectTV converter box (from home)work anywhere I go if hooked to a satelite dish. :)
I hear you on this. I use the Winegard Carryout MP-1 Portable SD dish with a DirecTV SD receiver from one of the bedrooms in my house. Works perfectly, and I am watching TV right now in a park that has very poor OTA reception.
I know your original question is about the possibility of renting an antenna to try out before you buy and I have never heard of such a rental. You can however rest assured that provided you can see clear sky where the DirecTV satellite is you will enjoy this unit. At $150 it is reasonable. I have been using mine for 2 years now without issue, except in Canada where the sat signal is blocked.
44,066 PostsLatest Activity: Jul 25, 2018
