- coolbreeze01ExplorerGood looking tires :C
- RDMuellerExplorerBack in business! I just jacked it up again, took 5 minutes. Thanks to everyone for the advice!
- TurnThePageExplorerI agree with the users that say to raise the other tire by driving it up onto something.
- DustyRExplorer
donn0128 wrote:
The one on the left in the picture is wrong. Take the tire off take a large pry bar and flip it over.
X-2
This is the appropriate repair. - I would use the jack. Too much stress as it flips while driving. Maybe just in my head.
- RDMuellerExplorerI'll give that a try before I get the jack out again!
- Gene_GinnyExplorerMy thought is that driving the right tire up on blocks will pull the equalizer up and put the left shackle in the correct position.
- CavemanCharlieExplorer IIIWhy not drive around the block slowly a couple of times and see what happens ? Try to go over a few bumps or pot holes as you do.
- hohenwald48ExplorerDon't let the pry bar smack you in the head. :E
- MFLNomad IIIt seems like if you'd just ramp up the front wheel with a couple 2x8s, pulling forward up onto them would correct the problem. If not, at least the weight would be off to turn the shackle over with a bar.
Jerry
