happy2rv wrote:
Hewey wrote:
Yes this is a brand new RV/furnace but I have used the furnace on/off since April(had a few early season cool nights). I would say atleast 10 hours of run time but nothing warmer than 18 Celsius up till this weekend.
Yes, only smelt when furnace is actually running. But not instantly, would be after its ran for awhile through some cycles then come back into trailer to. There is no smoke whatsoever just the smell.
Normally, I would think 10 hours would be enough to get burn off most of the coatings and such, but it depends on how long it actually fired vs just intermittent use. After our first fiasco, we opened all doors and windows and cranked it up to around 90F with an ambient temp of around 70F for an hour or so. After that, we had occasional light smell, but much less.
It's definitely worth checking things out. Verify that your co and propane detectors are functional.
Yah when heater would run it would only be for Run 3-5 mins each time. Maybe it never got hot long enough to actually burn any left over off.. got the heater fired up again right now to go check it in awhile before calling RV dealer.
The detector is working good, tested it last night. So that’s good to know.
