Xpd77's avatar
Xpd77
Potential Tire problem?
I'm currently traveling through Colorado carrying an arctic fox 811. I just stopped for gas and noticed a slight Ripple in the sidewall on one of my rear tires. I checked the tire pressure and found that it was over 90 PSI. This is after cold inflating them to 80 psi. Is it normal for the air pressure to get this high? Both rear tires were at this level of PSI. I went ahead and aired them down to about 83 PSI. Does anyone think I need to be worried about this?
  • Yes, temp rise causes pressure rise. And also modern tires will have slight Waves in sidewall
