RavensFan24
May 13, 2015Explorer
samhain7 wrote:
DOes your awning have the bars to drop the grade on one side to slant it for water flow? If you retract with those even dropped a little bit you will bend the arms...
Is that a possibility. I have only had two trailers, but they both retract flush.
I have heard of someone retracting their awning with the slant arms bent a bit and it messed up their awning...
I guess that is a possibility. Seems in 2015 if they have that option to adjust the arm, it should be able to still fold away properly. I opened it up partially and looked at how everything lays in there and it all looked square based on the eye test.
