Community Alumni
May 13, 2015samhain7 wrote:
DOes your awning have the bars to drop the grade on one side to slant it for water flow? If you retract with those even dropped a little bit you will bend the arms...
Is that a possibility. I have only had two trailers, but they both retract flush.
I have heard of someone retracting their awning with the slant arms bent a bit and it messed up their awning...
In the photos that the OP provided, it looks like an LCI Solera power awning which has arms that can be tilted/folded. These awnings are designed to be retracted with the arms either straight or tilted without causing issues.
