mat60
Dec 22, 2017Explorer
Power Awning
Been spent a lot of time getting ready for what may go wrong with new TT this winter. .This TT has a power Awning and was wondering if for some reason it wont retract how can you close it to get you h...
bobndot wrote:When they say it needs to be serviced, they mean it will need a new motor. When you manually roll it up, it ruins the motor.drsteve wrote:
It varies. On mine you need an allen wrench to remove a screw from the end of the roller tube, then you can manually retract it and reinstall the screw. Be sure to have a way to get to it, i.e. a ladder.
Consult your awning literature for details of your particular setup.
My awning is the same.
FYI : I was advised, once you do a manual roll up, do not con't to use it that way. I was told the manual roll up is a one time deal, that needs to be repaired before the next use.
