thejustin
Aug 21, 2013Explorer
Power (charging) problem with pre-owned Host camper
Sold my Lance 1161 and was able to get a Host Tahoe 1050 DS Dry bath. Gave it a brief shakedown but was having problems with the power side of the camper. I tried plugging in the shore power cable to my garage power outlet and it immediately trips the test/reset circuit and I cannot get any power inside the camper, and as a result, unable to charge the batteries. I tried several outlets in my house with a long extension cable, and none of them worked. Now these same outlets all powered my 5 other RV's/trailers without issue. Now oddly, it will not work plugged into my garage, but I tried plugging directly into my portable Yamaha 2000W generator and everything inside powered up fine.
Another thing I am not sure of, on ALL of my other RV's, when the generator was running the monitor panel would show the battery being "full" or 100% (even if it wasn't) so as to indicate the fact that the battery was currently being charged. Now when I plug into my Yamaha generator, or if I run the onboard Onan LPG generator, the battery is still at 75%, it does not jump to 100% leaving me wondering if the battery is even charging. I suppose I will need to go get a cheap Voltmeter and see for myself but it just seemed off to me. I should mention this is the first RV I have had with 6V batteries but not sure if that would make a difference or not.
Lastly, when I picked up the camper, I noticed the seller was using a portable battery charger wired directly to the battery terminals. I had asked why he didn't just run the shore power cable and have it charge that way but he didn't really give me an answer (I suppose he was most likely having the same problem I am).....
Any ideas?????
Any ideas?????
