westend
Mar 30, 2016Explorer
First, about the images and posting. This Forum has a problem with the code of Photobucket images. The "Percent20" can be removed from the Photobucket URL and a space added to post. You'll also want to specify 640 as the width of your image. The Forum will never post up a picture of your entire library. Individual images need to be selected. Another workaround is to post through the Woodalls portal as the code restrictions are not in place at that portal. I know, it's a pain and way too restrictive.
About the batteries-I have a pair of the same batteries. I think you'll like the way they work out. It may be possible to put your WDH brackets under the box and use spacers to attach the box, if attaching on top of the tongue. I have the same issue but welded in straps between the tongue angles.
Good luck with the batteries!
BTW, your original batteries have pushed electrolyte out the vents. You may be able to add water, recharge them, and get them back to usable. You probably will lose some capacity but they may be usable.
44,056 PostsLatest Activity: Jan 12, 2020
