westend
May 01, 2017Explorer
If you mixed up wires when connecting the battery, there is a good chance that you blew a reverse polarity fuse from the converter. Some distribution panels have two of these fuses on the front panel with the rest of the fuses and some RV's have the two fuses on the converter, itself.
TYpically, these fuses will be in the 30->40 amp range. If you list model and brand of your converter in this thread, someone may be able to tell you where they are located.
44,070 PostsLatest Activity: Jul 25, 2026
