jconway1006
May 02, 2017Explorer
Pretty sure the issue is the converter itself. However I already bought the correct fuses and will try that first.
beemerphile1 wrote:jconway1006 wrote:
...the two 30 amp fuses were blown. I put 20's in because I didn't have the 30's and they blew just as fast...Starting with the converter is the quickest solution to fix the problem.
You would rather buy and replace the converter than install the correct size fuse? :h
44,070 PostsLatest Activity: Jul 25, 2026
