Ok. I guess I'm a little confused as well.
I have my TT hooked up to 120v external power. Everything worked like it was supposed to last week. Now all the 120v stuff isnt working. The way this whole panel is wired up is kind of confusing to me.
My battery was completely dead when i plugged the TT into shore power. If I disconnect my 120v source, all the 12v stuff works. So this tells me my battery is working.
If I pull my breakers and test the bus bar behind them, I dont get any voltage at all there. You guys are saying that that bus bar should have 120v power all the time when connected to the house? The DC converter is connected to the breaker that is for the GFCI outlets in the TT. If my converter was bad, I would still have 120v, just all my 12v stuff would be gone once the battery drained......correct?
As long as I am connected to a 120v outside source, all my 120v stuff should work?
