Ok, so i checked everything. I get 120v from my house to the camper.
The 30 amp twist plug on the TT, does it run straight to the power center? I took the plug off and there is an orange wire connected to it. I look behind the power center and there is an orange wire connected to the Main breaker. I get no voltage on this wire. I shorted the wires together and tested for continuity at the plug....I got nothing. I think my wire is broken in two somewhere. I can rerun a new wire straight from the plug to the power center....But i want to make sure it goes straight there and not somewhere else first.
Any ideas?
EDIT:
I ran a cable from the plug to the breaker panel and everything started working. Off to Lowes to get a 10/2 MC cable I can strap to the frame and replace the one that is broken.
Just my luck a cable broke in two somewhere, somehow.
If somebody reads this and I shouldn't just rerun that cable straight from the plug to the power control center, please let me know. I have a feeling it stops somewhere first before running to the breakers, but I cant find it if it does.
