mkirsch
Oct 10, 2013Nomad II
splegge wrote:
Hi All-
I am unable to open my rear door all the way since the power jack in the way –
Has anybody else had this problem and how did they fix(reposition the jack) to allow the rear door to open all the way? is it possible to rotate the jack 90 degrees?
Typical trailer jack is mounted with 3 bolts in a flange at the "crotch" of the trailer tongue.
Relocating the jack... Is there even room? Usually there is a battery box and two propane tanks on the tongue, packed in between the jack and the front of the camper.
Even if you can move it back, you would need welding skills to put in a new flange mount further back.
You can rotate it 120 degrees. Don't know if that will help. If it's a matter of a fraction of an inch, it should work out.
44,066 PostsLatest Activity: Jul 25, 2018
