UGL's avatar
UGL
Power usage!?
My power bill was $173 last month!
I have a shop next door to my TT, but I have barely been out in the shop at all last month, haven't run HVAC or anything at all there.
As for the TT, I run the furnace here on 65* but it isn't getting that cold anymore.
Heres what the bill said: total kWh-1638, days-32, kWh per day-51,
Avg low temp-47, Avg high temp-64.
I keep it between 75-73* (A/C)fgtgvfhjnmjbgvjbn in here, I run a 12v fan that claims to use only a watt on high, and I sometimes leave my sleeping fan on 24/7, but its a little 8" Honeywell. I use a 40" LED flat screen, PC, and game console daily. The PC is a small tower BTW. Does all that add up to $173?
  • Can't find the cost per kWh on my bill lol.
    I used to own a 60X30 double wide that it's A/C was a ton to small, 95* plus temps costed over 2600 kWh!
    I'm about to move out of this thing anyway, getting a house built off the shop soon.
  • RoyB's avatar
    RoyB
    Explorer III
    Need to get a few things running off your BATTERIES and being topped off with a SOLAR PANEL...
  • My converter on float charge and my refrigerator use about $25 a month along. My electricity is about $.12 per Kwh.
    You're seems high considering the average home in this country only uses 1,000 KWh per month.
  • You didn't say what the charge is per KW hour. My only suggestion is to look at what you have on now that you didn't have on last year this month. That might give you a clue as to what's sucking up the $$. Also, see if they changed the charge per KWH
