OregonMan's avatar
OregonMan
Powering AC unit built into travel trailer with solar?
Hi guys I am looking to get solar set up for my travel trailer. It's a 2018 model and has a fairly efficient air conditioning unit built in to the ceiling/roof. I've watched YouTube videos showing how to use solar panels and a power inverter to power a window air conditioner, but what about when the air conditioner is built into the roof of your trailer? My trailer has a "solar ready" 10amp Furrion plug but I doubt that'll be enough to power the AC unit? Is there an adapter I could use to plug the power inverter directly into the 30amp power port on the outside of the trailer that I use to plugin at campgrounds?
Thanks for any tips on powering this built-in AC unit using solar panels.
  • If I could fit a mini-split in my 1140 AF I would have already. Just no good place to put one that will have a clear air path.
    You could just run from batteries, but they are pretty expensive too. Still Solar won't work at night so either way you need enough battery to carry you overnight. I have a 30 amp 12v-12v victron charger hooked to my truck that helps keep the batteries up while driving. We keep the AC on while moving and on all but the really hot days it will keep up fine with my solar. Last trip it was over 100 and I only made it about 5 hrs before I had to stop and fire up the generator. Drove the next hour with that on and was good for another few hrs. When its in the 80's, the truck and solar can keep up with the little cycling the ac does in days drive.
  • I've been thinking about a mini-split for my next camper and possibly solar and batteries to run the AC overnight, but solar is still pretty expensive.
    I was wondering if it is feasible to have a battery bank and invertor WITHOUT a solar setup. I was wondering if I stayed in a traditional campground night 1, charged the battery bank, then stay at a dispersed campground night 2 and use the batteries to power the mini-split overnight. Then either run a generator for a couple hours during the day to recharge the battery bank or stay at a traditional campground the following day.
    I'm still in the early research stages, as I've never done solar or battery/invertor before. Curious what people's thoughts are on this.
  • I run mine for short periods from two 206ah 12v lipo batteries. I have a 3000va victron inverter. The AC pulls 80-100 amps constantly. If your AC is a typical 12btu your going to need a lot of solar panels to pump 100 amps back into the battery. Or have a lot of batteries. I can usually last two to three hrs before depleting my batteries. Obviously the hotter it is, the less time I can do that.
  • A air conditioner that draws 12A AC would require an inverter that draws 130A DC from the batteries and would require a large solar array, battery and inverter. Basically it's just not practical for a RV.
    Instead use a 2000W gen or larger for your 30A RV to run the A/C.
